Can someone help me recover an unsaved Word document?
I was working in Microsoft Word for hours when my computer suddenly restarted, and I lost a document I never got the chance to save. I really need help finding any unsaved Word files, AutoRecover versions, or temporary files because this document was important and I’m trying not to start over from scratch.
This hit me a while back. I was wrapping up a six page report around 1 a.m., the laptop locked up for no clear reason, and I had to force a restart. I figured the document was dead.
I started with the usual places. I checked C:\Users\YourName\AppData\Roaming\Microsoft\Word\UnsavedFiles. Then I searched the whole drive for .asd files. I found one, tried opening it in Word, and Word crashed too. Great stuff.
The fix I ended up using came from this thread: https://discussion.7datarecovery.com/forum/topic/help-need-to-recover-unsaved-word-document/
The person there lays out a deeper recovery route with a tool that scans past Word’s normal autosave leftovers. In my case, it pulled back most of the file. I got roughly 90 percent of the document back. I lost the last chunk of edits, maybe 20 minutes or so, but at 1 a.m. I was willing to take the win and move on.
One part people skip over. Don’t launch Word again before you try recovery. I did some reading after the fact, and each fresh start of Word seems to risk overwriting temp data. If you’re unlucky, the file you need gets replaced and then you're done.
I’m still unsure about one part. If the document was stored through OneDrive, does this recovery path still pull local temp copies, or does cloud sync change where Word keeps them?
Start in Word itself first. File, Info, Manage Document, Recover Unsaved Documents. That pulls from Word’s internal cache, and people skip it all the time.
Next, check this folder:
C:\Users\YourName\AppData\Local\Microsoft\Office\UnsavedFiles
I disagree a bit with @mikeappsreviewer on one point. Reopening Word is not always fatal. Sometimes Word shows Document Recovery right away after a crash, and that is the fastest path. I would still avoid creating new files or saving anything first.
Also check temp files, not only .asd:
.tmp
.wbk
files starting with ~WRL or ~$
Search File Explorer with:
*.asd OR *.wbk OR *.tmp
If you had AutoBackup enabled, .wbk matters a lot.
For OneDrive, look in the web Recycle Bin and Version History. Word docs synced there often leave older states. If the doc existed once with any name, version history saves poeple all the time.
If none of that works, use Disk Drill and scan the drive for deleted temp Office files. Stop using the PC until the scan is done. That raises your odds.
This video is decent for recovering an unsaved Word document:
watch this unsaved Word document recovery walkthrough
I’d add one angle that @mikeappsreviewer and @waldgeist didn’t really dig into: sometimes the file is not sitting in Word’s recovery folders at all, but in your recent-file metadata or Windows file cache.
Try this:
  1. In Word, go to File > Open > Recent and scroll all the way down. Sometimes a “recovered” item shows there even when the main recovery pane does not.
  2. In Windows File Explorer, search by date modified instead of only by extension. Set it to “today” and sort descending. I’ve found orphaned DOCX files that way when .asd never appeared.
  3. Check this path too, because Office sometimes leaves junk there:
    C:\Users\YourName\AppData\Local\Temp
    Then search for:
    *.docx
    *.doc
    ~*.tmp
One small disagreement with @mikeappsreviewer: avoiding Word is smart, but if Word already offers a recovery pane on first launch, that can be worth taking before doing deeper scans. Just don’t start editing/saving random stuff.
If the document was ever emailed, attached, or previewed, also check Outlook temp folders and Windows Recent Items:
C:\Users\YourName\AppData\Roaming\Microsoft\Windows\Recent
If nothing turns up, then yeah, Disk Drill is a legit next move for unsaved Word document recovery because it can scan for deleted DOC/DOCX and temp Office remnants that normal search misses. At that point, stop using the drive as much as possible. Every minute of use can overwrite the bits you need.
Also worth reading Microsoft’s own guide for recovering lost, unsaved, or corrupted Word documents.
Big thing people miss: if the file was never saved even once, recovery odds depend heavily on whether AutoRecover had time to write a snapshot. If it crashed before that, the doc might be only partially recoverable. Annoying, but true.
One thing I’d add beyond what @waldgeist, @sternenwanderer, and @mikeappsreviewer covered: check Previous Versions / File History on the parent folder where you meant to save it. Right click the folder, Properties > Previous Versions. If File History, Restore Points, or OneDrive folder protection was active, you can sometimes recover the folder state even when the document itself was never manually saved where you expected.
I also slightly disagree with the “don’t reopen Word” advice when stated too broadly. If Word crashes and immediately offers recovery on the next launch, that first reopen is often your best shot. The real mistake is continuing to use the machine normally afterward.
Another overlooked place is Windows Restart Manager leftovers. After forced restarts, Office sometimes leaves lock/cache fragments that only show up if you search hidden items and system files enabled, then sort by date modified in AppData subfolders. Not elegant, but I’ve seen it work.
If the document mattered a lot and the obvious recovery paths are dry, clone the drive first if possible, then scan the clone. That reduces overwrite risk. Disk Drill is reasonable here.
Pros of Disk Drill:
  • easy deep scan
  • finds deleted DOC/DOCX and temp remnants
  • preview can confirm you found the right file
  • recovery is less reliable for never-saved files than people expect
  • scans can take a while
  • best results usually require stopping PC use immediately
If Word had not autosaved even once, recovery may only produce fragments. That’s the ugly part nobody likes to say out loud.
