I’m having trouble with Darlink Ai and can’t figure out what went wrong. It was working before, but now I’m stuck and need help understanding the issue, what may have caused it, and how to fix it quickly.
Start with the boring stuff first.
- Log out, close Darlink AI, reopen it, log back in.
- Check the service status page, if they have one. If servers are down, your side is fine.
- Clear browser cache and cookies, or reinstall the app if you use desktop/mobile.
- Turn off VPN, ad blocker, and browser extensions. Those break AI tools all the time.
- Test a different browser or device. This tells you fast if the issue is local.
- Check your plan, API credits, or usage limits. A lot of ‘it was working before’ problems come from expired billing or hit quotas.
- Look for the exact error message. Copy it word for word. Screenshots help too.
Common causes:
- Update broke a setting
- Account auth expired
- API key changed or got revoked
- Model endpoint changed
- File format or prompt size hit a limit
- Network/firewall blocked requests
If you use Darlink through an API, test one small request first. If it fails, check status code. 401 means auth issue. 429 means rate limit. 500 means server side. Thats the fastest way to narrow it down.
If you post the error text, what device you use, and what changed before it broke, people here can be way more specific.
@jeff already covered the standard reset stuff, so I’d look at what changed right before it stopped. That usually matters more than people think. If Darlink AI worked yesterday and not today, it’s often one of these:
- your account permissions changed
- the tool switched models/features in the background
- a saved workflow or custom setting got corrupted
- your input is triggering a filter now when it didn’t before
I actually kinda disagree with “reinstall first” unless the app itself won’t open. A lot of the time it’s not the app, it’s the session, account state, or a backend change.
Fast way to narrow it down:
- Try a super basic prompt like “hello”.
- Try the same thing with no attachments, no custom instructions, no saved template.
- If that works, the probelm is your workflow, not Darlink as a whole.
- If nothing works, test a second account if you have one.
Also check whether outputs are failing only on one feature, like chat vs upload vs image gen. That tells you way more than just “it’s broken.” If you can post the exact error and whether this is browser, mobile, or API, people can probly pinpoint it fast.
I’d check the boring stuff nobody checks: time, region, and billing state.
Sometimes Darlink Ai breaks because:
- system clock is off, which can mess with auth tokens
- VPN/proxy is changing region and a feature gets blocked
- payment renewal failed, so premium tools silently stop
- browser extensions like ad blockers or script/privacy tools are interfering
Quick isolation:
- open it in a private window
- disable extensions for one test
- switch networks, Wi-Fi to mobile hotspot
- check account billing/subscription page
- look at browser console or API response code if available
I slightly disagree with @jeff on one point: a second account test is useful, but network/environment tests usually expose the issue faster.
Pros of Darlink Ai: fast when stable, feature-rich, good for mixed workflows.
Cons of Darlink Ai: backend changes can feel opaque, errors are often vague, saved setups can fail silently.
If you post the exact error text, people can narrow it down fast.
Try a fresh chat frist, without deleting your old one. Send a short mesage like “Hello,” with no attachments or saved settings.
If it works, repeat your original request in smaller parts. This helps you check whether the trouble follows a specific message or attachment.
If the fresh chat also fails, contact support through the service’s help section. Include a screenshot, when the issue started, and the steps you tried. Keep your original chat until you’ve saved anything important.
If this stopped working for you at the exact same time it broke for other people, none of the local fixes above matter. Check community channels or their social feed before you touch anything. Half the ‘I reset everything’ stories end with the realization that the backend was down the whole time and the fix was waiting twenty minutes.
@shizuka’s point about the system clock is the one I’d actually bump up the list. Token auth failing because your device drifted a few minutes is rare but brutal to diagnose, since the error usually reads as a generic login failure and sends you chasing the wrong thing. Quick to rule out though, so do it early.
Where I lean away from the thread is the assumption that it’s your setup at all. ‘It worked before’ almost always means something changed on their end, not yours, especially with AI tools that quietly swap models or tighten content filters overnight. So before you reinstall or wipe cookies, send one dead-simple prompt and watch how it fails. A silent non-response points to backend or quota. A worded refusal points to a filter catching your input. Those are two completely different problems and the reset routine only helps with one of them.
