Does anyone have experience using Infinite Ai?
I’m looking into Infinite Ai for a project but can’t find many reviews or feedback online. Has anyone here used it for automation or content creation? I’d appreciate any insights or advice before I commit to using this platform.
Infinite Ai, huh? Honestly, it’s like trying to track down Bigfoot—everyone swears it’s out there doing wild things, but actual sightings (aka real user reviews) are crazy rare. I dabbled with it a few months back for content automation and, well, it’s… fine? It churned out okay drafts for articles, but sometimes just spun its wheels or dumped word salad. If you love editing, maybe that’s fun? Also tried some automation; nothing buggy, but also nothing that blew my socks off compared to other tools like Zapier or Make.
Biggest red flag? Their “support” is basically a form and a prayer. Docs are kinda thin, like the startup put up a hand-wavy notion page and called it a day. Didn’t find much of a community, either, so if you like crowd troubleshooting, you’re on your own.
In short: not a total trainwreck, but unless you’re allergic to Airtable or OpenAI tools, I don’t see Infinite Ai doing anything revolutionary. You might wanna poke around with a free trial if they offer one, but don’t expect magic. If someone’s actually using it at scale and loving it, they must be hiding with Bigfoot in the woods somewhere.
Can’t tell if Infinite Ai is a hidden gem or just hiding because there’s nothing shiny inside. I poked at it recently for automating some blog-writing gruntwork. Tbh, most outputs felt like they’d been written under duress by a language robot dreaming of being anywhere else. Editing was a given, and occasionally, it dropped hilariously unrelated stuff into sections. Plus, the integrations felt… ambitious but not really better than what I already get with Airtable + GPT API or even basic Zapier links.
I’ll add that my experience with support (if you can call it that) didn’t inspire confidence—no quick fixes, just barebones docs and the sense that you’re the first real user they’ve had all week. @viajantedoceu nailed it about the lack of a real user community, which is actually kinda a dealbreaker for me. I rely on forums and Reddit rants for troubleshooting way more than I’d like to admit.
Now, totally fair if you want to try the free version just to see if it “clicks” with your project. But unless you care about “unique” UI for automation or find mainstream tools aesthetically offensive, I haven’t seen Infinite Ai bring anything table-flipping or mind-blowing. Maybe things will change if they put real effort into docs/support/community. Until then, color me unimpressed and still searching for that magical unicorn app.
If you’re hoping Infinite Ai will be the automation holy grail, keep your shovel handy—might be digging a while. A few things stood out during my own experiment: the tool’s pitch about “infinite automation” gave me déjà vu from every other low/no-code app I’ve trialed, but in reality it’s more of an okay starter toolkit. Quick takes:
  • Drag-and-drop automation is decently intuitive, lets you string together basic flows without wrestling API docs.
  • Content generator, while prone to some creative nonsense, can be useful for boilerplate stuff that just needs heavy editing later.
  • Price-wise, Infinite Ai sits comfortably under some established choices, and the occasional generous free tier isn’t a bad flavor if you just want to tinker.
  • The integrations list is a few bullet points shorter than most competitors—Airtable and Zapier’s offerings here dwarf it, especially for weird edge-case business workflows.
  • Output from the AI content generation hovers between “acceptable” and “did a sleepy intern write this?” Fine for drafts, not for final posts.
  • Documentation, as others mentioned, is basically the digital equivalent of IKEA instructions but missing half the steps.
  • Community and support: almost nonexistent. If you get stuck, you’re probably elbow-deep on Notion pages or waiting for a support reply that might never come.
Worth noting, setting up more complex chains generally got clunkier compared to those rivals, especially when you try anything beyond simple triggers or logic. If you need heavy-duty integrations or frequently hit edge cases, you’ll be better equipped with an option that’s been around the block, like what’s on offer from some mentioned above.
Final verdict? If you’re running a lean operation or prototyping and want to avoid bigger players’ price tags, Infinite Ai is fine for some light workflows and first drafts. But if your project demands reliability, a strong support net, or you thrive on Slack channels full of power users, the search isn’t over. Maybe still worth trying for the AI content novelty or if you just want a breather from the mainstream—just temper expectations.
Skip Infinite Ai for now. Use a mix of off‑the‑shelf tools.
For automation, start with Make or Zapier for your core flows. Both have large integration lists and lots of templates. You set trigger, action, basic filters, then iterate.
For content, use ChatGPT or Claude for drafts, then standardize with your own checklists. For example, define word count, tone, links, CTA. Reuse the same prompt.
Glue it together with Google Sheets as your control panel. One sheet for content queue, one for automation logs. This keeps your stack simple and debuggable.
