I’m trying to show photos from my iPhone on the smart TV in our meeting room for my team at work. I connected both to the same Wi-Fi network, but the TV doesn’t show up when I open screen mirroring on my phone. I can use the TV’s remote, but I don’t know which settings matter.
How can I check whether this TV supports connecting my iPhone wirelessly, and what should I look for in its menus?
And I wouldn’t mirror the whole screen just to play a video. The DoCast app has separate photo, video, and music modes. I’d start there if a file is all I want on the TV.
Pick what you’re sharing
Sending a video directly should give smoother playback and leave the phone free for other things. Screen mirroring makes more sense when I actually need the TV to show what’s happening on the iPhone.
For a TV with AirPlay, I’d use Screen Mirroring in Control Center. Both devices need to be on the same Wi-Fi. That avoids adding an app when the built-in option already does the job.
If the TV doesn’t appear, I’d check the network before choosing another method. Keep both devices off guest Wi-Fi, turn off the iPhone’s VPN, and try restarting the TV and router.
Without AirPlay, I’d try DoCast mirroring. Open the app, let it find the TV, select it, then tap Start mirroring. It supports multiple TV brands, plus Chromecast, Roku, and Fire TV.
On Samsung, accept the connection prompt. An accidental Deny can be corrected under connected devices in the TV settings.
Keep a fallback
I’d also consider a cable if wireless isn’t cooperating. An iPhone 15 or newer uses a USB-C to HDMI adapter; older models need Apple’s Lightning to HDMI adapter. The tradeoff is staying physically connected.
My preference is to send the file rather than mirror everything. I’d change that if a comparison on my TV showed direct playback wasn’t smoother, or if I needed to show more than the file itself.
Don’t restart the office router without checking with IT, despite @anna_nerd’s restart suggestion. I’d first ask IT whether the meeting-room TV is on a restricted network and what method they support for sharing photos from an employee’s phone.
A TV that supports AirPlay but isn’t appearing is a different problem from a smart TV without AirPlay support. The iPhone’s built-in Screen Mirroring needs an AirPlay-compatible receiver, not simply a TV with Wi-Fi. I wouldn’t jump to installing a casting app yet. Can you post the TV’s exact model number and check its settings for an AirPlay option? That would help narrow down whether to troubleshoot the connection or choose a different sharing method.
Don’t waste the first half of your meeting trying to install apps and making your TV come alive! If you need the pictures to show on screen right away, separate the tasks ‘Get through this presentation’ from “figure out why my iPhone can’t find the TV.”
If there is a computer available in the meeting room, or your work laptop is showing on screen, you can share the files you need using your company’s agreed file sharing system. This will avoid having to connect your phone to the TV completely. However, if you do need to demonstrate something live on your phone this won’t help. But if it’s just a few pictures, it might not be worth connecting your iPhone.
That’s where I’d build on @leo88’s suggestion: ask IT how a visitor or employee is supposed to present in that room, rather than only asking why AirPlay isn’t working. There may be an established setup you can use without changing anything. A useful message would be: “I need to show photos from my phone. Is there a room computer or an approved way to send them to the display?” Less detective work, fewer experimental changes to office equipment.
Be careful with what you transfer. Create a new folder and move your meeting images across. Get them to order and open them all. Do NOT log your whole personal photo account onto a shared computer just to display a few images. The team require your project images and not an impromptu photo tour. Once you have finished, delete any temporary files from the shared computer and log out of anything you have used.
A TV that cannot be seen by any iPhones is a different issue than one that cannot be seen by your iPhone. I would ask a colleague to stand next to you connect to the same Wi-Fi network and open Screen Mirroring. This will help you compare.
As a beginner, this can be a bit confusing. The wording ‘it doesn’t connect’ can mean that you are either not seeing any name or it is not connecting. Here we are looking at the former. All you need to do here is compare the lists of devices.
If they have the device listed but you do not, then I would not adjust any TV settings. This won’t prove that there is an issue with your phone but you will have a more specific question to work on. If your phone is a company managed phone then it is worth informing IT. Sometimes managed Apple devices will have restrictions on the devices that you can Airplay to.
If neither phone lists it, I’d follow @dark_circuit’s model-number check before spending time on your iPhone. I wouldn’t treat two empty lists as proof that the TV lacks AirPlay, either. My next question would be whether anyone has successfully used an iPhone with that particular display, and what they selected to do it.
Once you’ve made the comparison you’ll be able to make sure you’re not adding any additional apps or doing any resets. “The display appears on my coworker’s iPhone but not mine” is much easier to work with than “the meeting-room TV won’t connect.”
Check the TV’s own settings for AirPlay toggled off before blaming your phone. Plenty of office displays ship with it supported but disabled, so it never shows up no matter how clean your Wi-Fi is. If you can’t get into those settings, the IT question @leo88 raised is really your only move.
Open Screen Mirroring and type in the name of the device. However, first have a look at the control panel in the room. If there is a 'present’/wireless share button, press it and see what appears on the screen.
Check if it is a different box connected by HDMI, in which case the brand of the TV is irrelevant. If it is asking for a name under airplay, type it exactly as it says. If a code is requested type in the code from the screen.
If the screen says it is using a different method of sharing and doesn’t mention airplay, do not continue refreshing the screen on your phone. Follow any instructions provided (if there are any) for using the iPhone in this room. If it does say airplay but does not include the advertised name, provide IT with the exact name and room number so they know to go to the receiver.
