How do I hard reset an iPhone?
Looking for a guide on how to hard reset an iPhone. My phone froze completely and nothing seems to be working when I try to restart it. Any step-by-step instructions or advice would be great.
Alright, here’s the deal. Your iPhone’s frozen like it’s been shoved in an Antarctic freezer, and now you’re freaking out. Relax. A hard reset isn’t brain surgery, k?
For an iPhone 8 and newer:
  1. Press the Volume Up button, let go.
  2. Press the Volume Down button, let go.
  3. Hold the Side/Power button until you see the Apple logo. Seriously, don’t flinch. Just HOLD. Apple logo means victory.
For iPhone 7 & 7 Plus:
  1. Press and hold Volume Down + Power/Side button together until the Apple logo crashes the party. Timing is everything here.
For older models (grandpa iPhone):
  1. Press and hold the Home button + Power button. Let the Apple logo lead you to salvation.
If this doesn’t work, well, either the universe hates you today, or your iPhone is trying to make you switch to Android. Just kidding. Sort of. But keep some patience and try again—it usually works unless your phone has deeper issues.
Okay, so @sonhadordobosque pretty much nailed the steps for resetting, but can we just pause and appreciate how unnecessarily stressful this whole process is? Seriously, why does Apple make it feel like you’re inputting cheat codes on an old video game console just to get your phone to listen to you again?
Here’s something extra they didn’t mention: make sure your fingers know their choreography before attempting this. Timing matters! You mess up one step, and instead of a rescue, you’re back at square one, staring at a frozen screen and questioning life choices. Been there. (Also, don’t press buttons for too long, or you might accidentally trigger SOS mode, which is a delightful nightmare in itself.)
Now, if this soft reset tango still doesn’t do the trick, there’s another card to play—plug that sucker into a computer and try a forced restore via iTunes (ugh, iTunes, I know). In iTunes, slap the device into recovery mode. It’s basically telling your iPhone, “Get your act together.” You might lose unsaved data, though, so brace yourself for possible heartbreak.
Also, worth saying, iPhones shouldn’t freeze this often (unless you’re running out of storage or have janky apps), so if this hard reset starts becoming a regular thing, maybe consider talking to a Genius Bar employee or doing the ol’ factory reset before you yeet it out a window.
At least we’re not dealing with 2003 flip phones anymore, I guess.
Alright, here’s a thought—while @nachtdromer and @sonhadordobosque put up solid advice for a hard reset, can we talk about avoiding these resets altogether? Sure, they mentioned how to reset every iPhone model known to humanity, but let’s rewind a bit and focus on why our devices are throwing tantrums in the first place.
Here’s my take: Prevention beats cure.
  1. Storage Woes: Low storage space is a silent killer for iPhones. Go to Settings > General > iPhone Storage. If it’s a red bar of doom, start deleting old apps and files.
  2. Software Glitches: Running outdated iOS versions? Update that sucker. Sometimes older software gets buggy; head to Settings > General > Software Update and get back in sync. Don’t be ‘that person’ clinging to an ancient version of iOS.
  3. Background App Drain: Too many apps running? Double-tap the home button (or swipe up and hold for newer models) and close them out. No one needs 40 tabs of Instagram running!
But hey, since this is a reset convo—here’s where I both agree and disagree with the steps laid out by the others. Yes, they’re clear on the key combinations—but let’s improve this whole setup. For anyone prone to accidental button-mashing (cough me), maybe practice these steps before you’re stuck in chaos mode. The button combos can be fiddly, and if you trigger SOS mode or attempt it wrong, talk about unnecessary anxiety. Also, why does the process lack a common standard across all models? Apple, maybe take a hint?
Pros of the Hard Reset:
  • Quick to execute (if you remember the combo).
  • No data loss, unlike a factory reset.
  • Bails you out in emergencies.
  • Might take a few tries due to button timing.
  • Can’t fix deeper issues (like hardware damage or major software bugs).
  • Can feel like typing a cheat code frustration— @nachtdromer did kinda nail this.
It’s worth briefly touching on alternatives if the reset doesn’t help. They mentioned recovery mode in iTunes (ugh, the horror), but in 2023, Finder for Mac is less clunky for this. Connect your phone, put it in DFU mode (different steps depending on iPhone model), and then restore. Heads-up: data loss is almost guaranteed here, so cross your fingers you’ve got iCloud backups.
Lastly, credit where it’s due—both responses serve the purpose, but improvements could include explaining troubleshooting mindsets or WHY these issues occur. After all, better to fix the cause than repeatedly hard-reset like it’s your survival mantra.
Try this before any hard reset.
Plug your iPhone into a charger. Wait 5 to 10 minutes.
If the screen stays frozen, connect it to a computer with Finder or iTunes.
Wait to see if it appears. If it does, make a backup first.
Then install any pending iOS update from the computer.
Many freeze issues stop after a clean update.
If it still locks up, remove heavy apps you used right before the freeze.
Those apps often trigger the hang.
