How do I scan for WiFi networks?
I’m having trouble connecting to my WiFi and I think it might be an issue with the available networks. Can someone guide me on how to scan for WiFi networks? My device isn’t showing any networks at all and I need to troubleshoot this.
Start by checking if your WiFi adapter is turned on. Sometimes it’s just a simple matter of accidentally turning off the WiFi switch on your laptop or turning off WiFi through settings.
1. Verify WiFi Adapter:
  • On Windows:
    • Click on the network icon in the taskbar.
    • Make sure WiFi is turned on.
    • If not, enable it.
  • On Mac:
    • Click the WiFi icon in the menu bar.
    • Ensure that WiFi is turned on.
Sometimes the WiFi adapter gets disabled in the device manager, it wouldn’t hurt to check there as well (on Windows):
  • Press Win + X and select Device Manager.
  • Look under “Network adapters” for your WiFi adapter.
  • If it’s disabled, right-click and enable it.
2. Drivers: Next, make sure your WiFi drivers are up to date. Outdated or corrupted drivers can cause your device not to detect any networks.
  • On Windows:
    • Go to Device Manager as mentioned above.
    • Right-click your WiFi adapter and select “Update driver”.
  • On Mac:
    • Updates come through macOS updates, so make sure your system is up to date.
3. Check Router/Broadband Modem: Ensure your router is functioning properly and broadcasting a signal.
  • Restart your router: Unplug it, wait a bit, and plug it back in.
  • See if other devices can connect to WiFi or not. If they can connect, the issue is probably with your device.
If those steps don’t work, scanning the available WiFi networks using specialized software can provide insight into what’s possibly going wrong.
NetSpot
Site Survey Software: It’s a good idea to use a dedicated WiFi analyzer tool like NetSpot. This software can help you scan for WiFi networks, detect dead spots, and optimize your wireless signal.
NetSpot is pretty user-friendly. Here’s a quick run-down on what you need to do:
  • Download and install NetSpot from https://www.netspotapp.com.
  • Open NetSpot and start a new project.
  • Choose a working mode such as ‘Survey’ or ‘Discover’.
  • Let NetSpot scan your area. It will show you all the available networks, their strengths, channels, and more.
This software can give you a ton of info on the state of WiFi networks around you, which might help diagnosing the problem.
4. Channel Interference: Nearby WiFi networks operating on the same channel can cause interference. NetSpot can help identify the channels used by nearby networks, allowing you to shift your router to less crowded channels.
  • Log into your router’s settings through a web browser.
  • Find the wireless settings section, look for the channel option.
  • Change it to a less crowded one as recommended by NetSpot.
5. Hardware Issues: If your WiFi adapter isn’t showing networks and no amount of tinkering with settings seems to help, it might be a hardware issue.
  • Try using an external USB WiFi adapter.
  • If other devices are not connecting either, the issue could be the router or ISP. Contact your internet service provider to rule out any network problems.
6. Network Reset:
  • On Windows:
    • Go to Settings > Network & Internet > Status.
    • Scroll down and click “Network reset.”
  • On Mac:
    • Go to System Preferences > Network.
    • Select WiFi from the list on the left and click the ‘-’ button. Then add WiFi again using the ‘+’ button.
In odd cases, some antivirus or firewall software might interfere with your WiFi connectivity. Disabling them temporarily can help to rule out these as the source of the problem.
Hope this helps! If you need more specifics or get stuck on a step, feel free to ask.
Hey, @codecrafter has already given you a pretty comprehensive step-by-step guide. A couple of areas I think might offer some additional insight:
Check for Airplane Mode: Sometimes we accidentally switch on Airplane Mode, especially on devices with touch or toggle buttons.
  • On Windows:
    • Go to the Action Center by clicking the speech bubble icon in the taskbar and ensure Airplane Mode is off.
  • On Mac:
    • There’s no direct Airplane Mode, but you can toggle WiFi from the menu bar.
Physical Obstructions: Do consider where your router is placed. Walls, metal objects, and even thick furniture can interfere with WiFi signals. Try moving the router to a more central location in your home.
Use Command Prompt: If you’re on Windows, you can use the Command Prompt to manually check for available networks.
  • Press Win + X and select Command Prompt.
  • Enter netsh wlan show networks.
This gives a quick low-level way to see if your WiFi adapter is picking up anything at all.
WiFi Analyzer Apps: Apart from NetSpot, there are other apps like WiFi Analyzer (for Windows and Android) and iStumbler for Mac users. These can also help map out signal strengths and interference.
  • WiFi Analyzer:
    • It’s an easy-to-use mobile tool available on the Play Store.
    • Good for quick checks and visual representation of channel congestions.
  • iStumbler:
    • Designed for macOS.
    • It provides detailed information on detected networks, like signal strength, channels, and security.
Sure, NetSpot is great, BUT let’s talk practicalities - some users find it a bit too detailed for simple troubleshooting. Whereas apps like WiFi Analyzer or iStumbler are more straightforward and user-friendly for quick scans.
Reset TCP/IP Stack (Windows): Another trick that sometimes helps is resetting the TCP/IP stack.
  • Open Command Prompt with admin rights.
  • Type netsh int ip reset and hit Enter.
  • Restart your computer.
Firmware Updates: Often overlooked, but routers need firmware updates too. Outdated firmware can cause connectivity issues.
  • Log into your router’s settings, usually by typing 192.168.1.1 or 192.168.0.1 into a browser.
  • Look for Firmware Update under settings.
ISP Problems: Sometimes the problem is upstream with your ISP. A quick way to check:
  • Plug your device directly into the router with an Ethernet cable.
  • If issues persist, a call to your ISP might be in order.
One more thing - a quick word on antivirus/firewall software - If you’ve got anything running that’s particularly enthusiastic about protecting your network, it could be blocking WiFi connections. A quick disable (with permission or caution, of course) might rule this out.
Lastly, Noise and Interference Sources: Other electronic devices, like cordless phones and microwaves, can interfere with WiFi signals. Make sure your router is placed far from such devices.
In regards to NetSpot, the primary pros are its detailed analytics and advanced features suitable for deeper diagnostics – it’s invaluable if you’re managing a complex network. However, the cons include its complexity and sometimes overwhelming data presentation for everyday users.
Competitors like WiFi Analyzer (Android) or Wireshark (though more complex) offer alternatives that can sometimes be easier to start with.
Hope these extra steps help you narrow down the issue!
I see a lot of good advice here already! Just to add another perspective that might help.
Power Cycle Your Device: Start with the basics! Reboot your device. Sometimes, a simple restart can solve a myriad of connectivity issues.
SSID Visibility: Sometimes the WiFi network’s SSID (network name) might be set to hidden. If you can access your router settings, make sure the SSID is broadcast. The steps to check this can usually be found under “Wireless Settings”.
WiFi Settings Reset (iOS/Android): If you’re using a mobile device:
  • iOS:
    • Go to Settings > General > Reset > Reset Network Settings. This will reset WiFi networks and passwords, cellular settings, and VPN/APN settings that you’ve used before.
  • Android:
    • Go to Settings > System > Reset options > Reset Wi-Fi, mobile & Bluetooth. This will reset WiFi networks and passwords, and other network settings.
Router Placement: Sometimes the issue is just where your router is placed. Make sure it’s in a central location and not near metal objects or microwaves which can interfere with the signal.
Check Network Boot Priority: On Windows, ensure that your network connection types are properly prioritized. Sometimes, Ethernet connections get priority over WiFi:
  • Go to Control Panel > Network and Sharing Center > Change adapter settings.
  • Press Alt, click Advanced > Advanced Settings > Adapters and Bindings.
Operating System Issues: There could be something wrong with your operating system. While updating the system is suggested, sometimes OS updates themselves cause issues. Googling specifically for known issues with your current OS/version could be enlightening.
Command Prompt WiFi Commands (Windows): Use the command prompt to get more hands-on:
  • netsh wlan show all – This command displays a detailed report of all the WiFi networks in range.
  • ipconfig /all – This shows all current network information.
Check Physical Connections: If this is on a laptop, sometimes the cables connecting your internal WiFi adapter might become loose. Refer to your laptop’s manual to check the hardware if you’re comfortable doing so.
Bluetooth Interference: Bluetooth operates on the 2.4 GHz band, so it might interfere with your WiFi. Try disabling Bluetooth temporarily to see if it helps.
UPnP and IGMP Settings: Sometimes issues arise from certain router settings:
  • Access your router settings.
  • Find and disable UPnP (Universal Plug and Play).
  • Consider disabling IGMP (Internet Group Management Protocol) as well.
IP Conflict: Sometimes, another device on your network might be using the same IP address. This can cause connectivity issues. Restarting the router often resolves this, but you might need to manually assign IP addresses for a more permanent fix.
NetSpot: Okay, I know it’s been mentioned, but seriously, NetSpot (https://www.netspotapp.com) can be a game-changer here. The detailed overview it gives you can uncover things you might miss with the naked eye. Just download, install, and let it scan for a comprehensive view of your WiFi environment.
While the advice given by others about updating drivers and checking settings is spot on, don’t overlook hardware issues. If none of these software tweaks solve the problem, consider testing your device with another WiFi network or even using an external WiFi adapter temporarily.
Hope you nail the problem soon! If your ISP provides no solution, seeking professional help could be your next step. Sometimes, tech support from ISP might overlook device-specific issues.
And just an aside - while disabling antivirus/firewalls as suggested might reveal the problem, keep security in mind. Should only be a temporary measure! Most times, tweaking settings within the antivirus software to allow WiFi through can be a safer approach.
Good luck, and keep us posted on what worked!
