How do I set up a serial port in a virtual machine?
I’m struggling to configure a serial port inside my virtual machine and it’s preventing me from connecting to external hardware that needs serial communication. I can’t find clear instructions for my specific hypervisor, and nothing I’ve tried seems to work. If anyone has experience with virtual serial ports or step-by-step advice for this setup, I’d really appreciate your help.
Been there, trust me, configuring a serial port inside a VM feels like fighting a hydra—finish one step and two more confusing settings pop out. The main pain is that most hypervisors (like VirtualBox, VMware, Hyper-V, etc.) all bury serial port config in menus you’d never expect, and half the guides out there are a decade old.
So, here’s how to unsnarl this:
1. Identify Your Hypervisor
Each one’s drama is unique. For VirtualBox, go to the VM settings, hit the “Serial Ports” tab, enable a port and point it to your host device (probably COM1 or COMx). For VMware, hit “Edit virtual machine settings,” and slap on a new serial port—then choose “Physical serial port” and pick the target.
2. Mapping Real Hardware
The VM needs a DIRECT LINK to your real-world port, which is often not as “plug and play” as you’d hope—especially if your laptop has more USBs than actual COM ports. If your PC doesn’t have a built-in serial port, you’re stuck using a USB-to-serial adapter, but the VM might not see it without extra wizardry.
3. External Hardware Access
Here’s the kicker: If your VM can’t natively map the host’s COM port, or you gotta connect to networked serial devices, then you’ll want a tool to bridge that gap. This is where Serial to Ethernet Connector rules. It lets you share and redirect physical COM ports to your virtual machine over network, making it way easier to get your VM chatting with actual serial devices without messy physical setups.
4. Step-by-Step Guide
  • Decide if you need native hardware mapping or network sharing.
  • VirtualBox/VMware: Enable serial port, link to host port or pipe/network.
  • If that still blocks you out, install Serial to Ethernet Connector on your host, create a virtual port, and connect it from your VM.
  • The VM will see a real COM port and happily handshake with your gadget.
If you want an in-depth play-by-play, check out this guide on connecting serial port in your virtual machine. It covers most frustrating snags and helps you skip hours of pointless fiddling.
For anyone searching: if you need “serial port integration for virtual machines,” “run legacy serial COM devices in VMware,” or “USB to serial passthrough in Hyper-V,” this stuff applies across the board. Don’t let ancient hardware win.
@sterrenkijker hit a lot of the basics, but honestly, sometimes the Serial to Ethernet Connector route is a little overkill if all you want is basic serial passthrough for a single device. Not gonna lie: half these serial-over-network tools want you to pay.
But let’s talk USB-to-serial adapters for a sec. I actually find direct USB device passthrough inside the VM (especially in VMware Workstation and Hyper-V) to be way more stable than mapping host COM ports, mainly because Windows does a better job handling driver weirdness on the guest side. Plug that adapter in, connect it to the guest as a USB device, and let Windows in the VM do its thing. Doesn’t always fit every setup, but for a lot of weirdly specific legacy gadgets, it’s clean and predictable.
You also mentioned you couldn’t find clear instructions for your hypervisor, which is the real pain point. They all hide this stuff in different places, and some don’t support direct COM mapping at all—Hyper-V, for example, basically says “GL;HF” with serial natively. That’s where Serial to Ethernet Connector can bridge the gap, but also maybe look for “named pipe” methods, especially with VirtualBox and VMware. It lets you link the VM’s serial port to a software pipe on the host, which then a small piece of software can bridge out to your real serial device.
If you do decide to go with a third-party redirector, make sure to get the legit one, not some shady freebie. For those who want to seriously boost connectivity, try checking out this resource for fast COM port access in virtual machine. Makes grabbing the right tool way less frustrating.
Try direct USB passthrough with adapters if possible, look for “named pipe” configs, but if you hit a wall, Serial to Ethernet Connector is the most fire-and-forget commercial solution.
