My hard drive suddenly stopped working, and I can’t access important files like photos, work documents, and backups. I’m looking for step-by-step hard drive data recovery help so I don’t make things worse or lose everything for good. What should I try first, and when should I stop and get professional data recovery support?
I wouldn’t freak out yet. I’ve had drives look “done” and still pull files off them later. The big thing is what you do next. If the drive lost data, stop using it right now. No installs. No big downloads. Don’t shuffle files around. Once new data lands on the same space, your old stuff is gone for good.
From what I’ve seen, recovery apps tend to work best when the problem is one of these:
- you deleted files by mistake
- you emptied the Recycle Bin
- the drive got quick-formatted
- a partition vanished
- files went missing after a freeze or crash
Different story if the drive is clicking, grinding, beeping, or dropping off the system at random. I’d stop there. Those are bad signs. Software won’t fix a failing head or other physical damage, and extra attempts sometimes make it worse.
If you want the simple route, I’d start with Disk Drill. I used it on a formatted external drive once and it was easier than PhotoRec by a mile. The layout makes sense, it scans deleted files and damaged file systems, and it works with external HDDs and SSDs. The preview tool helped me sort the good files from junk before restoring anything. On Windows, there’s a free recovery limit of 100 MB.
What I’d do, step by step:
- Install Disk Drill on a different drive, not the one with missing files.
- Plug in the problem drive.
- Launch the app and pick the affected drive.
- Hit “Search for lost data.”
- Let the scan finish, even if it feels slow.
- Use the filters or search bar to narrow things down.
- Open previews first. I always do this so I don’t restore broken junk.
- Select what you want back.
- Save the recovered files to another drive.
That last step matters more than people think. If you restore files back onto the same drive, you risk writing over other missing files you haven’t recovered yet. I learned this the dumb way years ago.
Before running a long scan, I’d also check the obvious places. Recycle Bin. OneDrive. File History on Windows. Time Machine on Mac. I’ve watched people spend half a day scanning a disk, then find the folder sitting in cloud sync the whole tiem.
If you want other options, these two are worth a look:
- PhotoRec. Free, ugly, effective. File names often come back scrambled, so sorting the output is a pain.
- UFS Explorer. Better if you know what you’re doing, especially with external drives and trickier cases.
If the drive isn’t detected at all, or it keeps making ugly noises, I wouldn’t keep poking at it with recovery tools. At that point I’d send it to a recovery lab. DIY software helps with logical loss. Hardware failure is a different mess.
Stop using the drive first. That matters more than any app.
If the drive spins up, shows in BIOS or Disk Management, and makes no clicking or beeping, start with triage:
- Test a new cable, new USB port, or a different enclosure.
- Check if the drive appears with the right size in Disk Management.
- If it shows up, do not run CHKDSK yet. I know people suggest it, but on a damaged file system it sometimes makes a bad sitution worse.
- If the files matter, clone the drive first with something like ddrescue or HDDSuperClone. Work from the clone, not the original.
- After cloning, run recovery on the clone.
This is where I slightly disagree with @mikeappsreviewer. Scanning the original drive first is fine for simple deletion cases, but if the drive “suddenly stopped working,” I’d put imaging first. Failing drives often get worse under long scans.
For logical loss, Disk Drill is a solid pick because it previews files well and handles damaged partitions better than a lot of cheap junk tools. Recover to a different drive only. Never back to the same disk.
If the drive clicks, disappears mid-scan, reports 0 bytes, or gets hot fast, stop DIY. Lab time.
Also, this thread might help if your issue is deleted files from an HDD:
step by step hard drive deleted file recovery guide
If the drive “suddenly stopped working,” I’d be a little more cautious than the usual just-run-a-scan advice. @mikeappsreviewer is right about not writing anything to it, and @yozora is right that imaging first is smarter if the disk might be failing. Where I slightly disagree is that people sometimes jump to pro labs too fast when the issue is just a bad cable, dead enclosure, or corrupted partition table.
My order would be:
- Power it down and stop using it.
- Try a different USB/SATA cable, port, power supply, or enclosure.
- Check BIOS and Disk Management. If it shows the correct size, that’s a decent sign.
- Do not format it, initialize it, or run CHKDSK yet.
- If the data matters a lot, clone the drive first.
- Then scan the clone or the original only if the drive seems stable.
For software recovery, Disk Drill is one of the easier options because the file preview is actually useful and it handles a lot of common logical-loss cases without being a total mess. Just install it on another drive, scan the problem disk, preview what’s recoverable, and restore files somewhere else. Not back to the same HDD. That part is where ppl mess up.
If the drive clicks, vanishes randomly, shows 0 bytes, or gets crazy slow, stop. Seriously. That’s when DIY turns into “welp, now it’s worse.”
Also, if you want a solid overview before touching anything, this Disk Drill review and hard drive recovery walkthrough is a decent quick watch.
I’m with @yozora on one key point: if the drive might be failing, image first beats “scan first.” But I’d push back a little on the idea that every weird case means instant lab time. A shocking number of “dead drives” are just bad USB bridge boards, weak power, or a corrupt partition entry.
My version of the order:
- Stop all writes immediately.
- Touch the basics first: swap cable, port, enclosure, power adapter.
- Listen and observe: normal spin = maybe recoverable DIY, clicking/beeping = stop.
- Check SMART if readable with CrystalDiskInfo or smartctl. If health is ugly or unreadable, avoid torture scans.
- If it mounts unstable, clone/image it.
- Recover from the image, not the patient.
One thing I disagree with @mikeappsreviewer on slightly: a long recovery scan is not always the best first move when the symptom is “suddenly stopped working.” Sometimes even browsing the file tree repeatedly is enough to push a weak drive over the edge.
If the issue turns out to be logical, not mechanical, Disk Drill is a reasonable pick after imaging.
Disk Drill pros
- easy preview of recoverable files
- good for deleted files, formatted partitions, lost partitions
- cleaner interface than a lot of recovery tools
- works well for people who do not want command line stuff
Disk Drill cons
- free recovery on Windows is limited
- deep scans can take ages
- not magic for physically damaged drives
- advanced users may want more low-level control
I’d also keep alternatives in mind depending on the case: PhotoRec for raw carving, R-Studio or UFS Explorer for harder jobs.
And yes, @suenodelbosque is right about one thing people ignore: do not initialize, format, or run repair tools just because Windows suggests it. That popup has trapped a lot of people.
Leave your drive unplugged and look for copies you already shared. On another device, search your sent email for a project name or filename. Check work chats for the latest attachment, or ask a coworker to resend thier copy. For photos, check your phone and camera cards for the originals before saving lower-resolution copies from a chat.
Save what you find to a seperate drive. Open each file and check its contents. List what’s still missing so you know whether you need disk recovery at all.
