The rehearsal folder on my sister’s SD card came up empty when I opened it to copy her choir recordings. The folder name is still there, and I can see the other folders on the card. She wants the audio files back so she can practice along with them at home. I haven’t saved anything to the card since I noticed they were missing.
The recovery program detects the card and gives me a choice of scan modes. Is it worth starting with a deep scan rather than a quick scan when the folder is still visible but the recordings aren’t?
An empty folder doesn’t mean you need a deep scan first. Unlike the CFexpress card in that detected card discussion, yours still shows other folders. I’d start with a quick scan because it may find the recordings with their original names. Save what it finds to your computer, not the SD card, and check that the tracks play. If any are missing, a deep scan can look for the audio itself even when the filenames are gone.
Search the entire card. If there are no results in the Rehearsals folder (this can easily occur if tracks were moved) then look at the date of the tracks rather than the names. If you get no results at all, refer to the section on CFexpress cards. If there are insufficient results, it is advisable to do a quick scan first.
Run a deep search. Although it is clear that the card is readable from the presence of the Rehearsals directory, there may be missing takes. Don’t put the card back into the recorder. Save any recovered data on your computer.
Don’t worry too much about recovering items from the CFexpress card. However, do not filter by date. Even if the audio file does not have the correct name, or reside in the correct directory, or the correct date, the deep search will locate the file. If a load of numbered files come up, try sorting them in length and listening to small parts of them in case they can be saved.
Are the files accessible from the other folders? It isn’t possible to know for certain from just looking at the names of the folders.
If you can get data off the card normally, and if these are the only copies of the choir recordings, then create a disk image of the card (a complete bit-for-bit copy) on your computer before doing anything else. Simply dragging across the folders will not recover lost audio from the missing space.
Do a quick scan. If you have missing areas, it might be worth doing the deep scan as well. As the SD card is not needed during the scan, you can do this without it in place. However, if the card is starting to have issues (disappearing in and out, or giving read errors) then I would not try doing multiple scans on the original.
Deep scan may be needed to recover files that weren’t recovered by a quick scan, or just partial files. Perform a quick scan of the card first. If rehearsal files are found, save and let your sister check for the end. If you can hear the choir beginning then it is the correct take. However, if you can hear the choir finishing, there is a lot more information.
It may be worth doing a quick scan first because the card may still contain information about where the parts of the file are located. By performing a deep scan to recover identifiable data, the beginning of the file can be found even if we do not know exactly where the recorder saved the rest of the file. If the recording was split into multiple pieces and the file is recovered in this way, it may stop part-way through. It could also start playing a completely different song.
If the recording is missing or stops abruptly, it may be worth performing a deep scan of the image. Save these in a different folder so that you have both versions to make comparisons. If however your sister is able to identify every take, and all of them play, it would be best not to.
This depends on why the files were lost. Was it accidentally formatted, or deleted? Or did the recorder run out of power/ crash while saving? If files were completely deleted, then they may be recoverable (but may have been overwritten). If however, the card was removed midway through writing, the tracks may be incomplete and no scanning will be able to recover them completely. It might be best to ask your sister what happened last with it!
The imaging advice from @quantumwizard3323zon is the part I’d actually act on first, and I’d put it ahead of any scan talk. If those recordings only exist on this card, make the bit-for-bit copy now and run every scan against the copy. That way a flaky card can die on you and you still have your one good snapshot. Same logic as the CFexpress card recovery discussion, where imaging early saved people from doing damage with repeated reads.
Quick/Deep options: Quick option is generally preferable. If using the Deep option, ensure that you have not missed items. Both options should be used on the image rather than the card. Do not sort results chronologically. Choir recorders will often label files in a way that does not reflect the actual chronology of the music.
Check whether recordings can be found in internal memory. Remove the SD card and change the recorder to record to internal memory. If there is a blank Rehearsals folder, it means that the recording has not been saved onto this card.
It is unlikely that a deep search of the card will contain the choir. If the recorder was set up to save to internal memory, it may take an evening to go through all of the old recordings on the SD card, and you may still not find the required recording.
However, if the recorder only saves to the SD card, or if your sister is certain that these takes were played from this card, perform a quick search of the image. If there are still unexplained takes, perform a deep search. However, do not perform a deep search simply because a larger number of results is returned.
The absence of a Rehearsals folder does not necessarily mean that the choir has been saved in the recorder’s internal memory. Even if Rehearsals appears in both places, it will not indicate which location the takes are in.
If the recorder has internal memory, remove the card and open up the playback list. The recording settings should not be changed. Ask your sister to search for the missing rehearsal. However, changing the location of future recordings will not indicate where previous recordings were made.
If the choir is missing, perform a fast scan. If the Rehearsals folder is still empty after a fast scan, do not perform a deep scan yet. Consider whether or not your sister can explain why the takes may not be present. If she cannot, and the audio is still missing, then yes, investing the time in doing a deep scan would be a good idea.
