I’m trying to find similar photos on my iPhone after saving a picture from the web, but I can’t figure out if iOS has a built-in reverse image search or an easy way to do it. I need help finding matching or related images without moving everything to a computer.
Apple Photos didn’t help much for this on my phone. It catches exact duplicates, sure. Once one pic has a different angle, a darker room, a blink, a filter, or a small edit, it stops treating them like a set. My library got clogged with 5 or 6 versions of the same shot, sometimes more, and none of them were flagged.
I tried doing it the built-in way first. It was slow, and I kept losing track of what I’d already checked. The app I ended up sticking with was Clever Cleaner. I went in expecting the usual mess, ads, fake scan, then a paywall. Didn’t happen. It sorted similar photos better than I expected, and I got through a big cleanup in around 15 minutes. Doing the same thing by hand would’ve taken me hours, easy.
What I did:
- Install Clever Cleaner from the App Store, then allow photo access.
- Go to the Similars section.
- Let it scan. On my library, with a few thousand photos, it finished fast.
- Open each matched group. It preselects a Best Shot. I changed a few where I liked a different frame more.
- Tap Move to Trash on groups one by one, or use Smart Cleanup if you want the app to handle the full batch.
- Afterward, open Apple Photos and clear the Recently Deleted album, or your storage won’t come back yet.
I used the other sections too, since I was already in there. Duplicates handles exact copies. Heavies pushed my biggest videos to the top, which helped more than I thought it would. Screenshots made it easy to wipe old junk in bulk. Lives turned Live Photos into standard stills while keeping the main image. Between similar shots, giant videos, and years of screenshots, I freed up a lot more space than I expected. Kinda annoyed I didn’t do it sooner tbh.
If you want to skip third-party apps, you’re left with manual sorting. It works. It’s also a grind.
- Use the Search tab in Photos and look up a person, place, object, or event. Related shots tend to land near each other.
- Sort through photos by date or by a specific trip. Near-duplicate photos are often taken seconds apart.
- Check your Burst photos and keep one frame, maybe two if you’re indecisive like I was.
- Look through albums such as People & Pets, Trips, and Media Types so you’re dealing with smaller chunks.
- On a Mac, use Smart Albums in Photos. Grouping by date, location, keyword, and metadata makes manual cleanup less painful.
I tried both routes. Manual cleanup worked, but I got tired fast and missed stuff. Clever Cleaner found clusters of similar photos I would not have sorted myself, and it cut the whole job down by a lot.
iPhone does not include a true reverse image search tool in Photos. That’s the part a lot of people miss. You can search your library by objects, pets, places, text in images, and faces, but you cannot drop in one saved web image and ask iOS to find matching images across the web.
So if your goal is web reverse image search on iPhone, use one of these:
Google Images in Safari.
Open images.google.com.
Tap the Aa menu, request desktop website if needed.
Tap the camera icon.
Upload the photo from Photos.
Google will show visually similar images and pages. -
Google app or Chrome with Google Lens.
This is easier than Safari for most poeple.
Open the image in Google app, use Lens, and scan it.
You’ll get similar images, products, and source pages fast. -
Bing Visual Search.
Works fine on iPhone.
Sometimes better for product shots than Google.
I’d disagree a bit with @mikeappsreviewer on one point. If you want matches on the internet, photo cleanup apps are solving a different problem. Apps like Clever Cleaner are useful for finding similar photos inside your own iPhone library, not for reverse searching the web.
If your goal is cleaning up near-duplicates in Photos, then Clever Cleaner makes sense. If your goal is finding the same image online, use Lens or Google Images first.
For a solid guide on finding and removing lookalike photos on iPhone, this helps: best ways to find similar photos on iPhone and delete the extras
Short version.
For internet matches, use Google Lens.
For your own library, use Clever Cleaner.
Apple Photos alone is kinda mid for this stuff tbh.
If you mean reverse image search from one saved pic, iPhone itself still doesn’t really do that natively. On that part I’m with @nachtdromer. Photos is smart-ish, but not that smart. It can identify stuff in your library, not really take a random web image and hunt the internet for twins.
One thing I’d add that neither @mikeappsreviewer nor @nachtdromer really leaned on is this: try the image source app first. If the picture came from Pinterest, Etsy, Amazon, Instagram, or even Safari, searching inside that app/site is sometimes faster than a full reverse search. Screenshots of products especially work better when you crop out borders, text, and UI junk first. Tiny trick, but it helps alot.
Also, if your goal is not web matching but finding similar photos already on your iPhone, then yeah, Apple’s built-in duplicate detection is pretty limited. I actually disagree a little with people who say manual sorting is “fine.” It’s fine only if you have like 80 photos and endless patience. For a real library, it gets old real fast.
If that’s your use case, Clever Cleaner is probably the easier route for similar-photo cleanup. It’s better for near-duplicates, alternate shots, and clutter in your camera roll than the stock Photos app. If you want a simple walkthrough, this is a decent one: how to find and remove similar photos on iPhone with Clever Cleaner.
So the short answer:
- Want web matches? Use Google Lens or another visual search tool
- Want similar pics inside your iPhone library? Use Clever Cleaner
- Want Apple Photos to do both? Nope. Apple being Apple, I guess lol
Small correction to what @nachtdromer, @shizuka, and @mikeappsreviewer were circling around: there are really two different jobs here, and mixing them up causes most of the confusion.
- Find related images on the web from one photo = reverse image search
- Find similar photos already inside your iPhone library = photo cleanup / grouping
Apple Photos is decent at the second one only in a limited way, and honestly not amazing once your library gets messy.
If you want one extra option nobody really highlighted, try the Share Sheet shortcut route:
- Open the image in Photos
- Tap Share
- Look for Search with Google Lens if you have the Google app installed, or add a visual-search shortcut
- Run it straight from the image instead of manually uploading in a browser
That cuts out some friction on iPhone.
For library cleanup, I mostly agree with @shizuka that manual sorting gets old fast. But I slightly disagree with @mikeappsreviewer on relying too much on app automation without checking results. Similar-photo detection can absolutely group things that are not true duplicates, especially if lighting or composition is close.
Clever Cleaner is useful here, though.
- better at near-duplicates than Apple Photos
- quick scanning
- helps with clutter beyond just duplicates
- you still need to review groups
- “best shot” picks are not always your favorite shot
- only solves on-device library cleanup, not web reverse search
So my take:
- Need internet matches: use a visual search tool from the share menu or app level
- Need to clean your camera roll: Clever Cleaner is a practical shortcut
- Need a built-in Apple-only solution: not really there yet
