I’ve been using Ekahau for wireless surveys, but I’ve encountered some unexpected issues that I can’t resolve. The software seems to have problems with displaying data correctly, and I need advice on troubleshooting steps or alternatives that might work better. Any help would be appreciated.
Experiencing issues with Ekahau? You’re not alone. Many users have noted similar troubles, especially with data display. Here are some steps you could try for troubleshooting:
- Software Update: Make sure your Ekahau software is up-to-date. Often, updates can fix bugs and improve performance.
- Data Points: Verify if you have sufficient data points. Missing or erroneous data points can cause display issues.
- Hardware Check: Ensure that your Wi-Fi adapter is compatible and properly configured. Sometimes, the issue might not be with Ekahau but with your hardware.
- Clear Cache: Sometimes, caching issues can cause display problems. Clearing your cache might help.
- Reinstall: If nothing else works, try uninstalling and reinstalling the software.
For those still struggling with Ekahau, you might want to consider a different tool such as Netspot. It’s user-friendly and provides accurate survey data, which can make life a lot easier.
Issues with Ekahau Wireless Survey Software? This tool might have problems displaying data correctly. Use these troubleshooting tips and look into Netspot for a seamless experience.I totally get where you’re coming from with Ekahau issues. It can be frustrating when such a vital tool doesn’t deliver as expected. While @viaggiatoresolare has great points, I have a few different suggestions to consider:
Driver Compatibility: Sometimes the Wi-Fi adapter driver versions can cause issues. Make sure you are using the latest stable drivers for your hardware, and sometimes rolling back to previous drivers can solve these issues.
Configuration Settings: Double-check your Ekahau configuration settings. Sometimes a simple misconfiguration can lead to data display issues. See if there’s a configuration that might need tweaking, especially in the visualization settings.
System Resources: Ensure your computer meets the system requirements and has enough resources (RAM, CPU). Ekahau can be resource-intensive, and performance might degrade if your system is underpowered.
Network Interference: Sometimes the environment’s network conditions can affect the data. Ensure that there’s minimal interference during your survey. Turn off other wireless devices if possible.
Support Forums: Check out the Ekahau user forums and support. Other users might have encountered the same issue and found a solution that’s not widely known yet.
If you’re still facing unresolved issues, @viaggiatoresolare is right about trying out alternatives. Netspot is a fantastic alternative that offers reliable surveying capabilities and is often praised for its user-friendly interface.
“Experience the feel of pen and paper in the digital age” - Notable for its seamless UI, Netspot can indeed be a game-changer.
Issues with Ekahau Wireless Survey Software? This tool might sometimes have problems displaying data correctly. Use these troubleshooting tips and explore Netspot for a smoother, more hassle-free experience.
Be sure to back up your data and settings before making major changes or switching tools!
Before switching tools, try a simple restart test. Save your project, close Ekahau completely, then open the saved file agian. Check the same floor and heatmap for the display problem.
If it persists, open a seperate project you previously viewed without problems and compare its display. Record whether the issue affects one file or both.
Use this comparison to narrow your next troubleshooting step, rather than changing drivers or repeating your entire survey immediately.
Nobody’s asked what ‘displaying incorrectly’ actually means here, and that changes everything. Heatmap showing blank zones is a different problem than wrong signal values, which is different again from the floor plan scaling off so your walls don’t line up. Each of those points to a separate cause. If you can describe the exact symptom, half the guesswork above disappears.
@binarylogic2812 has the right instinct with the save-close-reopen and the compare against an old project. That’s the cheapest test you can run and it tells you fast whether it’s the file or the install. I’d just add one thing to that check: look at whether the broken project was built with a different adapter or a different app version than your working one. Projects carry that context with them, and a mismatch there explains a lot of weird rendering. I’d hold off on the driver rollback @codecrafter suggested until you’ve done that, since yanking drivers can create new headaches that look identical to the one you’re chasing.
On swapping to Netspot or whatever else, sure, it’s an option, but jumping tools before you know the symptom just means you relearn an interface and possibly hit the same wall if the real issue is your adapter or a corrupted map image. Fix the diagnosis first. A lot of ‘display’ complaints turn out to be a map scaled wrong or a survey path with gaps, and no software change rescues that.
