I’m working on emotional scenes for an upcoming audition and keep freezing up when I’m supposed to cry. I can tap into the feelings a bit, but I just can’t get actual tears to come, and it’s starting to hurt my chances in callbacks. Can anyone share reliable techniques, exercises, or mental tricks that help you cry on cue without looking fake, especially under pressure or in front of a camera?
Short version. You do not need tears every time to book. But if you want them, train both emotion and body.
Some practical stuff that helps a lot of actors:
Separate “feeling” from “tears”
You can feel strong emotion and stay dry. Directors know this. Aim for truthful behavior first. Tears are a bonus.
Work the scene for given circumstances, objective, and stakes. If your body feels safe, it releases more. -
Use emotional prep, not trauma
Pick a personal “as if” that is specific and simple.
Example. “It is the last time I will see my dog.”
Give it 2 to 3 minutes alone before the take. Picture details. Smell, sound, one line they say to you.
Do not go to real life trauma over and over. That burns you out and makes you freeze. -
Use text triggers
Mark one or two lines in the script as emotional triggers.
Attach meaning to them in rehearsal.
Example. On the line “You did not even say goodbye”, you connect that to your “as if”.
Run it many times so your body starts to link the line and the feeling. -
Physical tricks that are normal on set
These are not cheating. They are tools.
• Strong yawns several times before the scene. Yawning brings real moisture to your eyes.
• Do not blink for a few seconds while you speak the tough line. Eyes water from strain.
• Breathe higher in the chest and shorten exhale. That mimics crying breath and often triggers the real thing.
• Look at a light source for a second, then back to your scene partner. Your eyes water a bit. Use it fast.
Pros also use menthol sticks. For self tape or class, ask first. It stings, so test it at home. -
Breath pattern
Real crying has irregular breath.
Practice this alone.
• Take quick shallow inhales.
• Let the voice shake on exhale.
• Add tiny sniff-ins between words.
You will notice your throat close a bit, the eyes start to sting, sometimes tears follow. -
Remove pressure around “I must cry”
The more you chase tears, the more your nervous system locks.
Before you start, tell yourself. “I play the need in the scene. Tears are optional.”
Often when actors drop the demand, the tears show up. -
Train it like a skill
10 minute drill, a few times a week.
• Pick a short monologue.
• Add your “as if”.
• Use breath pattern and focus on one specific loss or fear.
• Record.
Aim for consistency, not perfection. Even a light gloss in the eyes reads on camera. -
For the audition
Have two versions ready.
• One with full attempt at tears.
• One grounded, hurt, maybe only glossy eyes.
If tears do not come, you still give a strong, specific read. Many casting folks prefer truth over forced crying.
Last thing. Tears are a physical symptom, not the goal. If your inner life is clear, your listening is sharp, and your stakes are personal, you are already doing the important part. The moisture is the extra.
You’re already getting solid stuff from @sterrenkijker on tools and technique, so I’ll hit some angles they didn’t, and push back on a couple things.
First mild disagreement: I actually don’t think you should chase “crying on command” as the primary goal for this audition. Casting does love a visible emotional response, but what really kills a read is when they see you working hard to produce tears instead of playing the scene. A fully alive, hurting, contained performance often beats the one with big sobs and shiny cheeks.
Some stuff to try that isn’t just more tricks:
Build a cry vocabulary
Sit down and list 5 different flavors of “crying”:
• humiliated but holding it in
• numb and dry, then a crack
• angry-cry where you refuse to let them see you break
• quiet grief where your body is tired more than sad
• panic-cry, where breath is the main thing
Work each one. Your body may release tears on some versions and not others. You might be trying to force the “ugly cry” when the scene actually lives in a smaller, more internal version that your body can actually handle. -
Use sensory instead of just emotional prep
Everyone says “think of something sad.” Cool. But instead, try loading sensory details:
• temperature on your skin
• a specific smell that hits your gut
• the physical weight of something being taken away
Example: instead of “my partner left me,” use “my partner’s key is missing from the hook, and the space on the wall looks wrong.” If you can feel that little wrongness in your body, tears come way easier than from big abstract “this is so sad” thoughts. -
Let your body “fail” on purpose
This sounds dumb but helps with freezing:
In rehearsal, do 3 or 4 runs where you tell yourself, “I am not going to cry. I’m going to stay dry and just play the need.”
Take the pressure valve off. Then do one run where you’re “allowed” to cry but not required. A lot of people unfreeze as soon as their nervous system stops hearing “perform tears or you suck.” -
Rewrite the job you think you have
If in your head the job is “I must produce visible tears,” you’re basically trying to be a special effects department with a pulse. Change the job to:
• Make the other character matter like oxygen.
• Make the loss or danger specific and personal.
• Let the camera catch you fighting your feelings, not flaunting them.
Ironically, tears show up more when you play the resistance instead of the result. -
Check your physical baseline
Some actors literally cannot cry because their body is in “I’m not safe” mode all the time. That shows up as:
• locked jaw
• shoulders up by your ears
• shallow breath in upper chest even before you start the scene
Spend 3 minutes before working:
• shake out arms and hands
• stretch your face like an idiot, big ugly scrunch / wide open
• low belly breathing, exhale with sound
You do not need to be zen, but your body has to feel safe enough to risk vulnerability. Otherwise it clamps down exactly when you want tears. -
Watch what actually reads on camera
Film yourself on your phone in a simple scene. No pressure to cry, just hurt. Then zoom way in on your eyes.
You might notice:
• slight glassiness looks like “crying”
• micro tremble in eyelids and mouth plays stronger than full sobbing
A lot of actors think they’re “failing” because there’s no drip of water down the face. On a closeup, you honestly do not need much. What feels tiny from the inside usually reads huge. -
Give yourself a technical backup plan
I know @sterrenkijker mentioned some physical tricks. I’d add this: pre-decide what you’ll do if tears just do not come in the room. For example:
• You allow your voice to crack or go hoarse on one line.
• You let there be a long pause where emotion sits in your throat.
• You drop eye contact exactly once, like it hurts to look.
This way you’re not panicking mid-scene going “come on, cry, cry, cry.” You already have visible behavior that communicates the emotional hit. -
Practice “entering emotional state” on cue
Set a timer for 3 minutes.
• At 0:00 you are normal, talk out loud about grocery lists or something neutral.
• At 1:00 you silently flip a mental switch into your “as if” and sensory work.
• At 3:00 you start the scene.
Train your system to transition on schedule instead of expecting instant tears like a faucet. Consistency matters more than intensity.
Last thing I’ll gently argue with that a lot of teachers imply: no, you’re not “hurting your chances” just because you didn’t cry in a scene labeled “crying.” You hurt your chances if you play general, unfocused emotion or fake it. If your inner life is specific and alive, they can easily imagine actual tears there on the day with time, lighting, menthol, whatever.
Use this audition to prove you can live truthfully in the moment. If tears come, awesome. If they do not, make them miss you because the hurt underneath was undeniable.
Quick add-on from a slightly different angle.
You already got great technique from @codecrafter and @sterrenkijker. Instead of repeating, here are some complementary angles and a couple of disagreements.
1. Stop treating tears as “the high score”
Both of them are right that tears are optional, but I’ll push it further: some casting directors quietly dock points for obvious “I’m trying to cry” work. If you’ve got a solid, truthful, contained version, that can actually be the stronger choice for an audition. So:
- Prepare one version where the character is fighting tears hard
- Only then try a version where you allow tears if they come
Reverse the order from what most people do. First nail the “no tears, full stakes” read.
2. Anchor the emotion in action, not “sadness”
Both previous replies emphasize prep and triggers. I’d add: hone in on what you’re doing to the other person.
Instead of “I’m so sad,” try:
- I am begging you not to leave
- I am punishing you for hurting me
- I am trying not to let you see me fall apart
Your body often releases more when it feels like it is actively fighting for something, instead of passively “feeling.”
3. Use micro physical cues, not bigger tricks
They covered yawning, menthol, light, etc. I’m slightly skeptical of anything that pulls your focus off the scene in an audition room.
Try tiny, nearly invisible behaviors that suggest crying and often trigger the real reflex:
- Let your tongue press into the roof of the mouth while listening. Tension collects there and can push emotion up.
- Let your lower eyelids very slightly flex upward instead of widening your eyes. That “holding it back” shape is incredibly readable on camera.
- Relax your soft palate on an exhale. It gives that “on the verge of sobbing” sound without forcing tears.
These read emotionally even if tears never break.
4. Rehearse the “snap in” instead of staying loaded all day
They talked about emotional prep windows. One tweak:
- Don’t walk into the building already in grief
- Instead, practice a 30 second switch
Example drill:
- Neutral: talk about breakfast out loud.
- On a cue word, silently drop into your “as if” and physical pattern.
- At 25–30 seconds, say the first line.
You are building the transition muscle, which is exactly what casting needs: you can be chatting, then they roll, and you can drop in quickly.
5. Work the “dry cry” as a real skill
I mildly disagree with the idea that you should always keep chasing the real tear even in class or tapes. You actually need a reliable “dry cry” for the days your body just will not cooperate.
Drill a version where:
- Breath gets irregular
- Voice cracks once
- Eyes gloss slightly (from breath, not tricks)
- Jaw or hands show suppression
Film it. Many actors realize it already looks like they cried, even if their cheeks stayed dry.
6. Mental reframe to kill the freeze
Freezing is often, “I am being judged right now on whether my body leaks water.”
Swap to a measurable job:
- “I will let each word land inside me before I respond.”
- “I will not rush past any line that hurts.”
- “I will not protect the other character from what I feel.”
You cannot force tears, but you can guarantee those three behaviors. That sense of control calms your system enough that crying becomes more possible.
7. Pros & cons of relying on “crying on command”
If we treat “crying on command” as the product you are trying to use:
- Useful on set if the director needs matching continuity
- Great party trick for certain types of casting
- Builds your confidence that your body can respond when asked
- Can become a crutch, and you stop digging into text and relationship
- Risks emotional burnout if you access rough material carelessly
- In an audition, visible effort to cry can look more fake than staying dry but specific
@codecrafter’s approach skews practical and structured, great for consistent training.
@sterrenkijker added more nuance about not worshipping tears as the goal. Take what works from both, but do not treat any single method as the magic key.
Bottom line: build a clear, specific inner life, give yourself a simple physical pattern, and accept that the appearance of being emotionally hit is more important than liquid on your face. If tears show up, excellent. If not, your scene can still be devastating.
