I accidentally deleted photos and videos from my SD card, and now some files are missing after I tried using it again. I need help finding the best SD card recovery software that is safe, effective, and easy to use because these files are really important. If anyone has recommendations or tips for recovering data from an SD card, I’d really appreciate it.
I’ve had this happen, and yeah, it sucks. An SD card goes bad, or you wipe the wrong folder, or the camera suddenly says the card needs formatting. If the card itself is not cracked, bent, or dead at the hardware level, recovery software is usually your best shot.
First thing, stop writing anything to the card. No more photos. No more video. Don’t copy files onto it. I learned this the hard way years ago with a vacation card, one more batch of photos and some of the old stuff was gone for good. New data overwrites old data, and once it’s overwritten, you’re done.
Second, if your camera or computer pops up a format prompt, don’t accept it. Leave the card alone. Put it aside until you’re ready to scan it on a computer with a card reader. I would not do recovery through the camera connection if I had another option.
These are the tools I’d look at first:
- Disk Drill. This is the one I’d point most people to, mostly because it’s easier to work with and handles photo and video recovery well. You get file previews before paying, which saved me from wasting time once, and it supports camera RAW formats like CR2, NEF, and ARW. The part I liked most is its Advanced Camera Recovery mode. That matters if your missing files are from a GoPro, drone, mirrorless body, or anything else writing fragmented video files. Some apps find the chunks but return broken clips. This one tends to do better putting those pieces back into something playable. On Windows, it also gives you up to 100 MB free recovery.
- PhotoRec. No cost, open source, no recovery cap. It works. I’ve used it when I didn’t feel like paying for anything. The catch is the interface feels old and rough, and your recovered files often come back with generic names and no folder layout. If you recover 2,000 images, you’ll spend a while sorting.
- R-Studio and UFS Explorer. These are more serious tools. Good tools, too. I would use them if I needed finer control or if the card had file system damage, but they’re not the friendliest place to start if you’ve never touched recovery software before.
If you want the least annoying route, I’d start with Disk Drill. For SD cards, the big thing is video fragmentation. Cameras and drones split data in messy ways, and a lot of software sees the pieces without rebuilding them properly. If your goal is getting back footage you can open and use, this matters more than a pretty scan result screen.
One mistake people make, I did this once too, is saving recovered files back onto the same SD card. Don’t. Save everything to your computer’s internal drive or to another external drive. If you write recovered data onto the original card, you risk wiping out other files still sitting there unrecovered.
If the card disconnects randomly, reads slow, throws errors, or looks unstable, I’d make a full image of it first and scan the image instead of the card itself. Less wear, less risk. Better move if the card seems like it’s on its last legs.
So yeah, slow down. Put the card in a reader, scan it, preview what shows up, and recover to a different drive. I’ve seen cards come back from worse than I expected, so don’t write it off too fast.
