Need help finding the right iPhone 17 case
I just got an iPhone 17 and the case I ordered online doesn’t fit the buttons or camera cutout correctly. I need help choosing a protective iPhone 17 case that fits well, feels good in hand, and works with wireless charging.
Buy from brands with a solid fit record first. Spigen, Caudabe, OtterBox, Mous, and Apple usually nail button alignment and camera clearance better than random marketplace sellers.
What I’d look for:
  1. Raised lip, about 1.2 mm or more for screen and camera.
  2. TPU sides for grip, hard back for structure.
  3. Strong MagSafe magnets, around 1200g to 1500g hold feels decent on chargers and mounts.
  4. Clicky buttons, not mushy ones.
  5. Microfiber inside if you care about back scratches.
  6. Weight under 45g if you hate bulk.
Easy picks:
  • Spigen Rugged Armor, slim, grippy, fits well most years.
  • Caudabe Sheath, better hand feel, nice buttons, pricey.
  • OtterBox Symmetry, more drop protection, a bit bulky.
  • Apple Silicone, great fit, decent MagSafe, wears out faster.
  • Mous Limitless, strong magnets, solid protection, costs more.
If wireless charging matters, avoid thick metal kickstands and cheap magnetic rings. Those mess up alignment. If you want, post your exact iPhone 17 model and I’d narrow it down a bit more.
I’d do one extra thing before buying another case: make sure you didn’t accidentally get a case for the Pro or Plus version. That sounds obvious, but a ton of sellers bury the exact model in the listing and the camera opening ends up just sliiightly off. Been there, wasted money there.
I mostly agree with @codecrafter on sticking to known brands, but I’m gonna push back a little on Apple Silicone. Fits great, sure, but for the price it ages kinda badly if you’re rough on your phone. Corners get shiny, silicone can peel, and lint loves it way too much.
If you want a safer bet, I’d narrow it down by feel first:
  • Want slim and not slippery: Caudabe or Spigen Ultra Hybrid/Thin Fit
  • Want more cushion for drops: OtterBox Symmetry or commuter-style cases
  • Want soft-touch grip without huge bulk: Speck Presidio line is worth a look too
  • Want guaranteed wireless charging compatibility: look for “MagSafe certified” or at least reviews that mention charger heat and alignment
Big thing people forget is button design. Some cases technically “fit” but the button covers are stiff and annoying every single day. I’d read 1-star and 3-star reviews specifically for button feel and camera lip wobble on a table.
Also check return policy. Honestly, with new phone releases, first batches of acessories are sometimes rushed and the tolerances are all over the place. I usally avoid no-name marketplace brands for the first month or two.
