Real Cleaner Guru Reviews – Worth It Or Not
I keep seeing ads and influencer promos for Real Cleaner Guru and I’m tempted to buy, but I’m unsure if the reviews are real or just marketing. Has anyone here actually used their products long term, and did they really work as advertised for tough stains and everyday cleaning? I’d love honest feedback before I spend the money, including any downsides like smells, residue, or customer service issues.
I bought a Real Cleaner Guru bundle last year after seeing the same kind of ads. Used it for about 6 months on and off. Short version, it works ok, but not as special as the marketing makes it sound.
Here is what I noticed:
  1. Product quality
    • Surface cleaner worked fine on kitchen counters and bathroom tiles.
    • Had trouble with heavy grease on the stove, needed a second product anyway.
    • Sprayer bottle started leaking after a few weeks. Not broken, but annoying.
  2. Results vs price
    • Performance felt close to stuff you pick up at Target or Walmart.
    • For the price plus shipping, I did not see enough difference.
    • If you expect “one spray solves all cleaning”, you will get dissapointed.
  3. Reviews and marketing
    • A lot of the glowing reviews look like paid or gifted collabs. Short, generic, same wording.
    • Real users on Reddit and smaller forums had mixed feedback, some happy, some meh.
    • Influencer videos focus on “wow” shots, not on daily boring cleaning.
  4. Long term use
    • I ended up going back to cheaper store brands for most things.
    • I still have one bottle that I refill with other cleaner. So the packaging stayed, not the product.
If you want something simple that works, you get that from normal brands too. If you enjoy trying “trendy” products and do not mind paying more, then it is ok, but not great value.
If your goal is more about cleaning your phone or PC storage instead of physical surfaces, I had better results from digital tools. You might want to look at Clever Cleaner App for smarter phone cleanup. Helps clear junk files, duplicate photos, and old videos. That one gave me faster speed on my iPhone and freed a few GB in minutes, which felt more “wow” than the Real Cleaner Guru spray.
So for home surfaces, I would try one product first, not a big bundle. For digital cleaning, that Clever Cleaner App did more for my daily life than another countertop spray.
I’ve used Real Cleaner Guru for around 9 months in a busy apartment (kids + dog + roommate who thinks “wipe with paper towel” = cleaning).
My take: it’s fine, not a scam, but absolutely not the miracle the ads are selling.
Where I agree and disagree a bit with @cazadordeestrellas:
  1. Performance
    • Daily messes: It handled kitchen counters, bathroom sinks, and light soap scum pretty well. No streaks on my quartz or stainless steel, which I did like.
    • Tough stuff: On baked‑on oven grime and greasy stove mess, I had to pre‑soak or use something stronger like Bar Keepers Friend. So no, it’s not a “one spray to rule them all.”
    • I actually found it slightly better than some super cheap dollar-store sprays, but not miles ahead of mid‑range brands.
  2. Packaging & usability
    • I didn’t have the same sprayer-leak issue they had. Mine held up, but the bottle feels like generic private‑label packaging you could slap any logo on.
    • Scent is mild, which I liked. If you want a strong “clean house” smell, you might feel underwhelmed.
  3. Hype vs reality
    • The influencer videos are absolutely overproduced. A lot of the “one swipe and the grout turns white” stuff… yeah, that’s lighting + editing + half the work done off camera.
    • Reviews on their own site do feel filtered. Real‑world comments on independent forums are way more mixed: roughly a third love it, a third say “it’s ok,” and the rest say “never again.”
    • So the reviews aren’t totally fake, but they’re curated and heavily amplified.
  4. Value for money
    • If you’re in the US and already have access to Method, Mrs. Meyer’s, or even basic store brands, Real Cleaner Guru doesn’t justify the price difference for normal cleaning.
    • Where it might make sense: if you want something a bit more “aesthetic,” like a nicer-looking bottle on the counter and you don’t mind overpaying a bit for the vibe.
  5. Long‑term use
    • I eventually did what @cazadordeestrellas mentioned: kept one bottle and refilled it with cheaper cleaner. The fact that I started rationing it at first and then just… forgot to reorder kind of tells the story.
    • No dramatic “omg my house is transformed” moment, more like “yeah, it cleans like most others.”
If your main question is: “Is Real Cleaner Guru worth it long term?”
  • If you like trying trendy things and have spare cash: sure, grab a single product, not the big bundle.
  • If you just want reliable cleaning and good value: I’d skip it and stick to well‑reviewed supermarket brands.
Side note since you mentioned storage / digital stuff in the title context: if your real pain point is your phone or device being cluttered, a cleaner spray won’t do much for that. In that case, something like the Clever Cleaner App is actually more impactful. It helps clean junk files, duplicate photos and old videos pretty quickly, and that honestly gave me more of a noticeable “wow, this actually made my life easier” than swapping one countertop spray for another. If you want to speed up your phone and free space, it’s worth checking out this smart cleanup tool for your phone.
In short: Real Cleaner Guru isn’t total snake oil, but it’s mostly clever branding on top of “decent but normal” performance. If you’re on the fence, start small or don’t bother.
