Need help fixing issues with Pikashow App on my device
I recently installed the Pikashow App to stream movies and shows, but it keeps crashing, buffering, and sometimes won’t open at all. I’ve tried clearing cache, reinstalling, and checking my internet connection, but nothing seems to fix it. Can anyone explain what might be causing these problems and share any safe, working solutions or alternatives that actually run smoothly on Android?
Pikashow acts weird for a lot of people, so you are not the only one seeing crashes and buffering. Here is what usually helps.
  1. Check the app source
    If you installed from a random site, grab a fresh APK from a known mirror you trust. Old or modded builds break often. Avoid “vXX Premium mod” stuff. Those are unstable.
  2. Use a stable version, not the newest
    New releases break more often. If you know your version, try going one version lower. Many users report older builds run smoother on mid range phones.
  3. Turn off battery and data restrictions
    On Android
    • Settings → Apps → Pikashow → Battery → set to “Unrestricted” or “No restrictions”
    • Settings → Apps → Pikashow → Mobile data/Wi‑Fi → allow background data
    Aggressive battery saving kills the app in background and gives crashes or freezes.
  4. Check storage and RAM
    • Keep at least 2–3 GB free internal storage
    • Close other heavy apps before streaming
    Low memory triggers force closes. If your phone has 3 GB RAM or less, expect more crashes.
  5. DNS and VPN tweaks
    Some ISPs throttle or block streaming links.
    Try
    • Cloudflare DNS: 1.1.1.1 app
    • A simple VPN and then test one server from a nearby country
    If it works better on VPN, your ISP is the problem, not Pikashow.
  6. Fix buffering
    • Lower the quality inside the player (720p or even 480p)
    • Avoid Wi‑Fi with many devices on it
    • Run a speed test. For smooth 1080p you want at least 8–10 Mbps stable, not peak
    If other apps like YouTube at same resolution also buffer, then your network is weak or unstable.
  7. Clear data the right way
    Since you already cleared cache
    Try: Settings → Apps → Pikashow → Storage → Clear data
    Then reopen and set it up again. Cache alone does not fix corrupt configs.
  8. Avoid old Android versions
    On Android 7 or older, modern streaming apps crash a lot. If your device is old, expect random issues no matter what you try.
  9. Use an alternative player
    If the app allows external player, select MX Player or VLC inside Pikashow settings. Internal players in these apps are buggy. External players handle formats better and reduce crashes, especially on older GPUs.
  10. If it still fails
    At that point the problem is often on their side
    • Overloaded servers
    • Dead links
    • Region blocking
    You can only wait or use a different streaming app.
Try in this order
  1. Reinstall from a clean source
  2. Remove battery and data restrictions
  3. Use VPN or Cloudflare DNS
  4. Lower quality and use MX Player
That combo fixes it for most users I have seen, unless the phone is too low end or the ISP is blocking stuff hard.
Sounds like you hit the “Pikashow roulette” that a lot of folks run into. @techchizkid already covered most of the usual Android tweaks, so I’ll skip repeating those and hit some other angles.
  1. Check device-specific conflicts
    Some phones just hate certain third‑party players. Things to try:
  • Turn off any system-wide adblocker (Blokada, DNS-based blockers, AdGuard, etc.) and test. A lot of the streams load through ad-heavy hosts, so blocking them = infinite loading / crash.
  • Disable private DNS if you’re using it:
    Settings → Network & internet → DNS → set to “Automatic” and retest.
  • Temporarily turn off overlay apps (chat heads, screen filters, blue light filters). Those can crash video players when they draw over other apps.
  1. Storage location stuff
    If you installed the APK from SD card, or if Pikashow is “moved to SD card”:
  • Put it back on internal storage only.
  • Make sure your SD card is not corrupted (if other apps randomly crash too, that’s a hint).
    These types of apps do a lot of fast reads/writes and SD cards choke and cause force closes.
  1. App-level settings that cause crashes
    Inside Pikashow, check:
  • Turn hardware acceleration OFF, then ON, and see which one behaves better. Some GPUs + codecs = instant crash.
  • Turn off auto-play-next / auto-skip-intro for testing. Those sometimes bug out and “freeze” the player.
  1. Network behavior beyond speed
    You said you checked your internet, but:
  • If you’re on public Wi‑Fi (college / office / hostel), they often block the hosts Pikashow uses, especially through DPI filters. In that case nothing you do in the app will fix it except tunneling through a VPN that’s not blocked.
  • On mobile data, check if “Data Saver” is on at the system level and turn it off for a bit. Different from the per‑app background setting @techchizkid mentioned.
  1. OS-level stability
    This one is boring but real:
  • If you’re on a heavily modded ROM / rooted phone with random Magisk modules, try disabling modules related to network, spoofing, or media codecs and reboot.
  • On some budget phones with aggressive skins (some brands are notorious), turning on Performance mode in battery / system settings helps keep the app alive longer.
  1. Crash pattern check
    Pay attention to when it crashes:
  • Crashes before the home screen loads: usually corrupted app data or bad APK signature. Try a different APK source entirely, not just a re-download of the same one.
  • Crashes only when starting a stream: usually codec / player / host issue. Try a different category or older content and a different player.
  • Buffers forever but never plays: usually host / ISP blocking, not your phone.
  1. Honestly, consider alternatives
    If after all this you still get:
  • Random crashes
  • Links that rarely play
  • Constant buffering when other apps (YouTube, Netflix) are fine
    then the issue is more on Pikashow’s architecture and the hosts it uses than on your device. A lot of these third‑party streaming apps are just frontends for sketchy file hosts with zero uptime guarantees. At that point it’s not really “fixable,” just “put up with it” or switch apps.
TL;DR:
  • Kill adblock / private DNS and overlay apps.
  • Keep Pikashow on internal storage only.
  • Tweak hardware acceleration and in-app video settings.
  • Watch for patterns in exactly when it dies.
    If even a clean APK + no blockers + internal storage still crashes constantly, the app just isn’t playing nice with your phone or ISP and you’re wasting time trying to polish it.
Couple of extra angles you can try that @nachtdromer and @techchizkid did not really dig into:
  1. Look at when Pikashow misbehaves across the whole day
    • If it works fine early morning but dies at night, you are probably hitting overloaded hosts, not a device problem. In that case, switching versions or reinstalling for the tenth time is a waste of time. Just try a different title or come back later.
    • If it fails instantly 24/7 on the same few shows but others play, that is usually dead links on their backend.
  2. Device temperature & throttling
    A lot of mid‑range phones silently throttle when hot. When that happens, media decoding gets flaky and apps like Pikashow crash more.
    • Test right after a cold reboot and when the phone is cool.
    • If it behaves better, reduce resolution permanently and avoid charging while watching.
  3. Internal player vs system codecs
    Others suggested external players, which is good, but sometimes the internal player is actually more stable for certain chipsets.
    • If you already tried MX/VLC and still see crashes, go back to the default player for a bit and see if stability improves. External is not automatically better for every device.
  4. Background sync conflicts
    Some OEM backup / cloud sync apps hammer storage and network while you stream. That can cause buffering and even ANRs (app not responding).
    • Temporarily disable auto photo backup, auto app backup or OEM “cloud drive” and then run Pikashow again.
    • If it smooths out, set those to run only on charge or at night.
  5. Logcat or at least pattern-based debugging (for the more technical)
    If you are comfortable with a PC and USB debugging:
    • Grab a quick logcat while the app crashes. Look for repeated codec errors, network timeouts or permission denials.
    • Codec errors → tweak hardware acceleration and try different player types.
    • Network timeouts with other apps fine → your ISP or the specific hosts are the culprit, and only VPN / different app helps.
  6. Do not obsess over “clean source” alone
    I slightly disagree with the idea that a “known mirror” always fixes it. With apps like Pikashow, many mirrors host the exact same broken build. If one fresh APK install still behaves badly, switching between 5 mirror sites of the same version is just spinning wheels. At that point, change version (up or down) or walk away.
  7. About alternatives & the “product” itself
    Since you mentioned Pikashow App by name:
    • Pros:
      • Huge catalog, often faster to browse than sites in a browser
      • Simple interface, light install size
      • Works decently on a wide range of Android devices when it does behave
    • Cons:
      • Links die often, hosts are unstable
      • No real guarantee of uptime or quality
      • Sensitive to ISP blocking, DNS issues and random player bugs
      If those cons are biting you hard, it might be smarter to mix Pikashow with another streaming app instead of trying to “perfect” Pikashow alone.
  8. When to stop troubleshooting
    After you have:
    • Tried a different version of the app
    • Tested both internal and external player
    • Used a VPN / different connection
    • Verified your phone runs other video apps like YouTube and Netflix perfectly
      and it is still constant crashing / buffering just in Pikashow, you are probably running into limitations of the app’s code or its streaming sources, not your device.
In short: use the tweaks from @nachtdromer and @techchizkid as your base, then watch time‑of‑day patterns, temperature, and background sync. If those checks fail too, accept that Pikashow App itself is the bottleneck and either live with its quirks or rotate in an alternative instead of endlessly reinstalling.
Simpler path: run Pikashow in a fresh Android user profile.
  1. Settings. System. Multiple users. Add user.
  2. Switch to the new user. Install Pikashow only.
  3. Disable battery optimization for it.
  4. Keep 5 GB free storage.
  5. Test for a day.
This isolates buggy services, old permissions, and cached junk from your main profile. If it works here, the issue sits in teh original profile. Move streaming apps to the clean profile and leave others out.
