Is anyone else having problems with the Grindr app suddenly crashing, freezing, or not sending messages? It was working fine before, and now it’s glitchy and unreliable. I’ve tried basic troubleshooting but nothing sticks. I need help figuring out what’s causing this and how to fix it so I can actually use the app again.
Yeah, Grindr has been a mess for a lot of people lately. Crashes, stuck on “Sending…”, messages not loading, random logouts. Some of it lines up with their recent app updates and backend changes, so it is not only your phone.
Things to try that often fix it, at least for a while:
Check status first
- Go to Twitter / X and search “Grindr down” or “Grindr not working”.
- Check sites like DownDetector for spikes.
- If you see a big spike in reports, it is on their side, not yours.
Clear cache and data
- Android: Settings → Apps → Grindr → Storage → Clear cache. Test. If still bad, Clear data, then log in again.
- iPhone: Offload App in Settings → General → iPhone Storage → Grindr → Offload App, then reinstall from there.
Fully reinstall
- Delete the app.
- Restart phone.
- Reinstall from Play Store or App Store.
- Log back in with email or Apple/Google.
- Do not restore from a phone backup, install fresh.
Turn off VPN and ad blockers
- Grindr often breaks with VPNs, firewalls, private DNS, or ad blocking apps.
- Disable these, then test messages and browsing.
- If it works fine after that, the filter or VPN is the problem.
Check storage, battery, and background limits
- Make sure you have at least a few GB free storage. Low storage makes apps crash more.
- On Android, turn off Battery Optimization for Grindr. Settings → Apps → Grindr → Battery → set to Unrestricted or similar.
- On iPhone, disable Low Power Mode while testing.
Try mobile data vs WiFi
- If it crashes or hangs only on WiFi, your router or DNS might block some connections.
- Switch to mobile data and test messages and profiles.
- If it works fine on data, restart router or change DNS to something like 8.8.8.8.
Turn off “Data Saver” and “Low Data” modes
- Android: Settings → Network → Data Saver off.
- iPhone: Settings → Cellular → Cellular Data Options → Low Data Mode off.
- These modes sometimes kill push connections for chat.
Disable “Nearby Refresh” type features
- If the map or grid is laggy or freezing when it loads profiles, try turning off extra views like Explore or extra filters.
- Heavy filters and distance sorting tend to stress older phones.
Check for app version bugs
- Go to the app store page and read the recent reviews.
- If lots of users complain after the latest update with similar stuff as you, it is likely a version bug.
- In that case, you have two options:
• Wait for the next update.
• On Android, try sideloading an older version from a trusted mirror, though that has risk and is not for everyone.
Log out and back in
- Open profile → Settings → Log out.
- Fully close the app.
- Open and log back in.
- This sometimes resets stuck sessions that break messages.
- Turn off “Background App Refresh” for other heavy apps
- If your phone is older or low RAM, too many apps in the background make Grindr die more.
- Close TikTok, Instagram, games, then run Grindr.
- Collect evidence and report
- When it crashes, note:
• Time
• What you were doing (opening a chat, sending a pic, refreshing grid)
• Your phone model and OS version
• App version (shown in Settings in the app) - Send a bug report through Grindr support. Include screenshots if messages hang on “Sending”.
My own pattern on Android 13:
- 50 to 100 chats, tons of old media, app starts to get slow and crash.
- Clearing data and logging in again drops local history but stops most crashes for a while.
- Crashes spike after big app updates, then ease off after a patch in a week or two.
So if you already tried the “basic” stuff like restart and reinstall, I would focus on: clear data, disable VPN/adblock, check battery optimization, and see if a specific update triggered this by reading reviews on the store. If all of that still fails and DownDetector shows issues, it is on their side and no local tweak will fix it permanently.
Same here, it’s been acting like it’s held together with duct tape lately.
@ombrasilente already covered most of the “normal human being” stuff to try, so I’ll skip the obvious cache/reinstall/battery tips. A few extra angles that helped me when it went totally feral:
Check whether it’s only certain features
Is it crashing when:- Opening a specific chat
- Sending pics
- Viewing albums
- Tapping a particular profile
If you notice it only dies on one convo, try: - Blocking that profile temporarily
- Or opening the chat from a notification instead of from the chat list
Corrupted media or a broken profile sometimes kills the app on load.
Turn off in-app features, not just system stuff
Inside Grindr settings, try:- Disable “Show Typing Indicators”
- Disable “Read Receipts” (if you have XTRA/Unlimited)
- Turn off autoplay for videos / GIFs if that’s in your version
These keep a persistent connection and I’ve seen them cause the infinite “Sending…” thing more than once.
Trim your chat history
This is one point I slightly disagree with @ombrasilente on. Clearing all data is a nuclear option and nukes everything. Before that, try:- Manually deleting a bunch of dead chats, especially old ones with tons of pics
- Clearing out saved photos in your phone gallery that came from Grindr, if your phone is low on RAM/storage
For some reason, massive message histories make the chat list crawl and crash more, particularly on older phones.
Turn off system-level “bubble” / overlay stuff
If you’re on Android and using chat bubbles, floating notifications, or screen overlays (like Messenger bubbles, screen dimming apps, blue‑light filters, etc.), try disabling those. Grindr sometimes hates drawing over other apps and just gives up. -
Check if it hates your account, not your phone
Sounds weird, but:- Log into your account on a different device (friend’s spare phone, old phone, tablet)
- Or create a throwaway test account on your phone and see if that one works smoothly
If your account is buggy on every device but other accounts work fine, something is borked on their backend tied to your profile. That’s when you spam their support with specifics.
Watch what happens around location permissions
- Temporarily set location permission to “Allow only while using the app” (or the strictest non‑deny mode your OS has)
- Then try opening the grid, then messages
If it hangs mostly when loading nearby guys, sometimes the location lookup or their ad/analytics layer tied to it is choking. I’ve had fewer crashes by not giving it “Always allow” and forcing it to refresh location only when I open it.
Try changing the app’s language / region
Super random trick but it actually helped me once:- Change phone language to something else (like English to Spanish), open Grindr, then switch back
This forces the app to rebuild some resources and can shake out weird UI crashes.
Check if any “accessibility” tools are interfering
Stuff like:- Accessibility readers
- Tap‑to‑click helpers
- Gesture/navigation overlays
They sometimes conflict with touch handling in poorly optimized apps. Disable them for a bit and see if scrolling/chats still freeze.
When you report it, be a bit annoying about detail
Since this looks like a more widespread instability lately:- Take a short screen recording of it freezing/crashing
- Note exact timestamps and what action you took right before it died
- Mention your city/region and network (some bugs hit specific CDNs or regions harder)
Support usually ignores vague “it keeps crashing” but will escalate if you look like unpaid QA.
Right now you’re not imagining it, this version really is jank for a lot of people. If none of the above gives even temporary relief and other apps are solid on your phone, then yeah, you’ve basically reached the “wait for their devs to fix their stuff” stage and just use it in short bursts so it doesn’t drive you nuts.
Couple of angles that haven’t really been touched yet:
Look at system logs (more advanced)
- Android: enable Developer Options, plug into a PC, run
adb logcatwhile you reproduce the crash. - iOS: in Settings → Privacy & Security → Analytics & Improvements → Analytics Data, look for recent Grindr entries.
If you see repeating errors tied to a specific module (for example image decoding, webview, or location), that tells you what is actually breaking so you can avoid that feature for now (like sending pics vs just text).
Check WebView / system components
A lot of chat apps lean on the system’s WebView. On Android:- Update “Android System WebView” from the Play Store.
- If you are on a custom ROM or very old OS, WebView bugs can cause exactly the freezing and random crashes you describe.
Sometimes this alone stabilizes things more than reinstalling Grindr ten times.
OS version vs app version mismatch
Personally I have seen Grindr behave worse on the very latest iOS / Android for a couple of weeks after a big OS update. In that window:- If you just updated your phone OS, this might simply be that the app is lagging behind compatibility wise.
- In that case, I would actually avoid nuking all data repeatedly and just keep it minimal: fewer chats, no heavy media, short sessions, wait for the next Grindr update.
Network-level shaping & carrier quirks
If you are on a smaller or stricter carrier, they sometimes do traffic shaping that hurts apps like Grindr more than, say, WhatsApp. Quick checks:- Try a different SIM in the same phone, or use a cheap prepaid eSIM for a day.
- If Grindr behaves fine on the second carrier, the original provider is throttling or interfering.
In that scenario, no number of reinstalls will completely fix it.
Consider using the web or a backup app
When Grindr is unstable after all the tricks from @sonhadordobosque and @ombrasilente, the practical play is to have a backup:- Use their web interface if available in your region, at least to read messages when the app keeps crashing.
- Or keep a secondary dating app around and mirror your core contacts there.
This is not a “fix” but it keeps you reachable while Grindr is in one of its buggy cycles.
Slight disagreement on endless nuking of data
Constantly clearing data and reinstalling can create its own problems: repeated logins, two-factor issues, and a higher chance of triggering security flags on the backend. I would treat a full wipe as a once-in-a-while reset, then leave it alone unless the app becomes completely unusable again. -
About “” itself
Since you mentioned fixing issues on your phone in general, tools like “” can be useful for:- Centralizing app crash reports so you see patterns over time.
- Highlighting which apps are hogging memory or CPU before Grindr dies.
Pros: - Helps you see if Grindr is the only unstable app or if your whole system is borderline.
- Can automate some cleanup so low storage / RAM problems are less likely.
Cons: - Extra background service, so it may add a bit of overhead on very old devices.
- Not a magic bullet; it cannot fix a bad Grindr update or server-side problems.
Where @sonhadordobosque and @ombrasilente fit in
- @sonhadordobosque covered a lot of solid, practical user-level steps: connectivity checks, reinstall strategies, and general cleanup.
- @ombrasilente went deeper into specific Grindr behaviors like certain chats or features causing crashes and some clever workarounds.
If you combine their “front line” advice with the more diagnostic stuff above (logs, WebView, carrier testing), you should at least be able to tell whether the problem is: your device, your network, your account, or simply the current Grindr release being a mess.
If all signs point to “this version is broken for many people” and your other apps are healthy, then the realistic path is: keep your usage light, avoid media-heavy chats, run occasional checks with tools like “”, and wait out the next update cycle instead of tearing your phone apart every day.
Try removing battery and background restrictions for Grindr. This often fixes delayed mesages and freezing without reinstalling anything.
On Android, open Settings, Apps, Grindr, Battery, then select Unrestricted. Under Mobile Data, enable Background Data.
On iPhone, open Settings, General, Background App Refresh, then enable Grindr. Also turn off Low Power Mode during testing.
Restart your phone and test for 15 minutes on Wi-Fi. If it works, your phone’s power setings were limiting Grindr.
If your grid loads fine but messages stick on ‘Sending,’ that’s their chat backend choking, and none of the battery or cache stuff will touch it. Worth separating those two symptoms before you tear the phone apart. @cacadordeestrelas already made the point I’d underline hardest: repeated data wipes and re-logins can get you tripped by their security checks, and then you’re stuck fighting email or captcha loops on top of the original bug. I’ve seen that turn a mild annoyance into a locked account. The @kernelnode5670 battery fix is genuinely the highest value low-effort thing here for delayed messages, so try that first. But honestly, if DownDetector is spiking and other apps on your phone are steady, save yourself the afternoon and just check back after their next update. This app has a habit of breaking after a release and quietly patching itself a week later.
